PCM codes 1518 0446 0420 ???
bayareadude84
Methahoma(temporary)
hey guys have a '01 burb 5.3 with 200K miles
My CEL is on and I ran the codes
p1518
P0446
P0420
I don't have any throttle issues at moment,just a rough idle at times.And I do have the fuel pump wire recall #05V155 to be fixed at dealer and thinking it might fix one or more of these issues ??
Any ideas what to check or what parts to buy before I start throwing $$ at it ??
Thnx,
Dave
ccapehartusarmyINF.(ret)
Gilbert AZ
the p0446 is an evap emissions system
p1518 throttle actuater control is sending invalid info to the PCM
does yer vehicle crank slow when you start it if it doesn check voltage coming out of yer battery
if voltage is fine check your brake and cruise fuses
p0420 is the bad catalytic converter code but it cant also mean yer post cat 02 sensones are the problem or you got a really big exhaust leak wich you probably dont
jojo
Evap purge vent for p0446 just had the same problem there's a black rectangular box slightly larger than a pack of cigarettes under the vehicle near the fuel tank and spare tire unplug the electrical plug remove it now you can get a new filter and try to clean it. I just bought a new one and installed it.
B
bayareadude84
no it doesn't crank slow,few months ago I put in new Diehard battery throwing out 14.4 volts
cleared the codes drove around for 2 days and today just p0420 stays says lean bank 1
---------- Post added at 07:36 PM ---------- Previous post was at 07:24 PM ----------
meh :wtf: $100 for a new canister PASS lol,Luckily the state I live in has no emissions !!
When I get bored one day ill remove it and try to clean out any buildup
Dave
sparky 843
