mikez71
- Joined
- Mar 9, 2023
- Posts
- 1,588
- Reaction score
- 1,860
To manually power it up, you would need wires hooked up to your battery. Test for power first. I would disconnect the pedal motor and see if it still makes the same clicking sound. Also you will need to press the pedal adjust switch while you test for power.
Since you'll have your meter out, you can test the motor resistance instead. Put your leads on the motor connector pin 4&5 (what the purple and yellow wires plug into) and set it to ohm measurement. If it is shorted, it should be at or close to 0.
