pegged oil pressure gauge, jumpy after replacement?
BlueCollarTahoe
had a pegged oil guage sensor so i changed it out. the start up after and driving around was back to normal. start up after sitting 6 or so hours it was pegged again. start up late in the afternoon was normal. its jumpy. any ideas?
BlueCollarTahoe
BlueCollarTahoe
now its just pegged all the way to the end. no back and forth. thoughts?
HiHoeSilver
Away!
Chicago
how can i find it?
I wish I had a good answer for you. I'm not saying it's not the stepper, either... But intermittent and pegged, then bouncing, then fine.... Sounds like a short to me. I think all you can do is trace the wires... Are you sure the plug is seated well? Did you keep /reuse that little gray insert piece?
sunshinetou22
