Picked up an OEM looking Backup camera worth $700 for $30 :)
coopiesb
wichita falls, tx
and got a qoute for paint and install on all the body stuff so going in after the tune then just sterio is left....... looking at 3 l7 12's with a 2500.1
DenaliAK
Colder than you
Alaska
Aaaaaaaaaaarrrrrrrgggggggggghhhhhhhhhhhhhh
Well, my camera worked for about an hour. Now it's just showing a sort of static on the screen. Somehow lost signal from the camera. I know it's not the camera, cause I swapped in my original and got the same result.
Any ideas? I'm getting power, just not a signal. Had to splice some more power and ground wires, but I don't think I'd even be seeing the screen light up if those were the issue.
dropmech
Puddle Pirate
Coral Springs
Where are you tapping in for power and ground?
DenaliAK
Colder than you
Alaska
Power I'm using ignition 3 fuse tap.
Ground is a bolt left of the fuse box.
GhostHoe
(r33p1n 1n $h4Ð0w$
Charlotte, North Carolina
Mine does the same thing. Sometimes it works and sometimes it doesn't.
I'm going to just wire it to a toggle so I can flick it on and off until it works lol.
dropmech
Puddle Pirate
Coral Springs
The problem with using bolts, is if there is any paint, corrosion, even a washer of a less conductive material (i.e. aluminum), it won't give you as good of a ground as if you simply went to an actual ground point or an existing ground wire that you can splice into. I don't see why you guys simply don't splice into the reverse light wiring. It works.
GhostHoe
(r33p1n 1n $h4Ð0w$
Because we want it on at all times.
Max
Mile High
Denver
I'd want a 7" screen anyway, hell of a deal if you're not getting a 2din tho.
lbtahoe
