Picked up an OEM looking Backup camera worth $700 for $30 :)
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
you'd need a ground, ignition power and the wire for reverse i believe. I think the switch is a dpdt (double pole, double throw)
Pat
Anthony
Anthony
2004 Tahoe LT (MA)
Westen MA
WOW! I just got home from work and saw the box at my door....
I opened it and...It looked BRAND NEW. It even had the plastic stuck on the screen like when you buy a new screen, all the wires were in their original packaging and the wires were not even spliced...I hooked it up inside and it works 100% and the picture quality is great! So now maybe later this week I'll get it in the Hoe, anyone here install a Back-up camera and recommend a certain way to run the wires to the back?
Thanks!
jESse
i like cheese
michigan
seems oddly like one of those too good to be true things but if you got yours and it works no problem, i might as well go for it too. just snagged another up on a buy it now for $30
Anthony
Anthony
2004 Tahoe LT (MA)
Westen MA
spent 90 mins. today installing the unit and properly hiding all the wires, (triple checked everything lol) WOW picture quality is clear, the radius of the camera is large and I will pick up a switch later this week to help control the unit (Kill switch for cops).
Ill add pics later this week.
Also The seller still sells these for $30 every few days, so I recommend to pick 1 up :)
DenaliAK
Colder than you
Alaska
Now I'm sitting here trying to find another one of these on ebay.....lol. That's a crazy good deal.
And of course I can't find it anywhere. :(
DenaliAK
Colder than you
Alaska
I contacted the seller via ebay messaging asking if he had more, he did, put one up for sale, and I quickly bought it. $30 and no shipping fee....how does he make anything off of this deal? Not that I'm complaining.
Anthony, I may have installation questions since I suck at figuring wiring out.
jESse
i like cheese
michigan
wheres an easy to access switched power source near the center console area? i wired all mine in today and got it working but its just on a toggle right now. i want a wire to splice into that will just automatically switch it on and off with the key
---------- Post added at 07:51 PM ---------- Previous post was at 07:08 PM ----------
heres a couple quick pics of it.
DenaliAK
Colder than you
Alaska
I've got a Denali and my Traction Control button is right where this goes, so I'm going to have to find a new home for that. I never touch it, anyway.
Jesse, that looks pretty slick. How much of a pain was it to get the dash off? I also would like to wire it so it is on whenever the car is on, so I can use it like an extra rear-view mirror (like RV's use).
jESse
i like cheese
michigan
dash is just held in with little clips. just grab around the edges and gently pull it out. not sure how your switches are mounted up in there cause i just had the pocket but that just popped right out and the screen pops in where the pocket was mounted. took not even 5 minutes to put that part in
dacpdx
