JoeOmerta
So over the weekend i replaced the transfercase input shaft seal and the rear pinion seal. I marked the pinion nut and my buddy counted the threads. When reassembling everything, my buddy thought i went past my mark by 1/8-1/4 turn but i thought i was still 3/4 turn short.
After going for a test drive now anywhere above 50mph, if i let off the throttle, or go back on the throttle, i get a quick grinding noise. But no noises any other time. Does this sound like the pinion is too loose or is this more of a too tight scenario?
Could i have reinstalled the transfercase wrong? it's only 6 bolts and i feel like that would leak or make a ton of noise all the time.
Click for SOLUTION
Click for SOLUTION
