TogaPC
When was the last time you tuned up your engine...plugs, wires, fuel filter, cleaned MAF and Throttle body? Do you SeaFoam? Do you have a Performance Tune?
The rattling at higher RPM's may be a sign that a crank or cam bearing is going out. I would probably take it easy till you have a mechanic tell you otherwise.
FYI - My tahoe did this one morning last month when I parked outside and it was in the 30's. Sounded really bad for about 30 seconds then started idling normally. I also got a MIL for Multiple Random Cylinder Misfire. This has not happened since but I park in a garage. I also have a Black Bear 93 octane tune and I think my fuel pump is starting to go out so all those factors may have contributed to the rough idle.
