SnowDrifter
- Joined
- Sep 5, 2016
- Posts
- 2,445
- Reaction score
- 2,688
There's 2 points that control the position of your relay rod
1 is the pitman arm/steering box
2 is the idler arm/idler arm bracket
There are a few things you can check. Take a peek at both the pitman arm and the idler arm. Compare to images online to insure nothing is bent or out of whack. Do the same with your idler arm bracket. If all of that checks out, it would leave your mounting points. Was your vehicle ever in a wreck? Are the frame or mounting points for the box/bracket tweaked out?
