please help asap with LPP LTs
hoe
Ill go snap some pics of my clearance for him. But yea headers can be a real pain in the arse to get fitted at first, but I have had good luck, if you use the header for the right application.
DaUsedMCR
DaUsedMCR
San Bernardino, CA
the steering shaft was bending when the header was on. it wasnt just sitting against it. he said that it was nearly 2" too far over to fit. i opened the hood and revved the engine and it didnt move barely at all, so i dont know if its the mounts... are there any slimmer steering shafts i could buy to fit on? is it safe to grind down the shaft?
hoe
ok, well the clearance is tight on mines, and I did not have to bang or beat anything. So you have a issue here. I am able to still slide my car keys in between my steering shaft and header primary.
Was the frame damaged or altered in anyway? your steering shaft is the same, as mine, and mine is also a 01. I did break my steering shaft, so be careful, but a used one from a 99 at the junkyard to fit it perfect.
---------- Post added at 05:02 PM ---------- Previous post was at 04:51 PM ----------
Passenger side
DaUsedMCR
DaUsedMCR
San Bernardino, CA
i dont believe the frame was altered at all. the shop i was at was an exhaust shop. im gonna take it to my normal guy tomorrow who said he could get an engine mount and take a look to see if its leaning and how it would compare to a new engine mount. im really hoping the engine is leaning because i really want these headers to fit!!!
Travieso
Boooooooost !
Los Skandeles, CA
man that sucks bro, i dont recall me having any issues with the steering shaft let me take a few pictures and try to help you out brb
***************************** edit for pics *************************************
here you go
here is the passenger side
Hope this helps you, gl hopefully everything will work out for you
DaUsedMCR
DaUsedMCR
San Bernardino, CA
thanks for all the pics everyone. like i said, tomorrow im gonna go see my normal mechanic and see what he thinks about them. maybe he can fix it and put the headers on as well. im really hoping that he can spot a problem and fix it. if these end up not working, im gonna see if LPP will let me exchange them (with money back to me) for their racing shorty headers. they should fit exactly where the stock manifolds were right? i know long tubes are much better, but some extra HP is better than no extra HP right? i was gonna do a cat delete with the shorties as well
hoe
got them things on yet dude?
MsGofstr
