PLEASE Help. Condenser freeze up
04chevyhoe
2008 tahoe. After running the air conditioning for 30-45 minutes the evaporator(silver canister under the hood located on the fire wall)-also the coil( radiator looking thing in the duct work under the dash )will freeze to solid block of ice and no air will come out of the vents in the dash- the rear air (second and third row)will continue to work.
If you shut off the air or turn on the heat to thaw it, it will work for another 30-45 minutes.
I have used compressed air to blow out the drain tube, didn't help. Have tried to recirculate and not recirculate but neither one cures the issue.
I have checked all the blend doors and they are operating. I have checked the blower motor, it is working correctly.
Please help.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
or the freon is too low/high
BRUTUS_T_HOG
The cycling switch on the accumulator is the most likely cause. They are cheap and require no special tools to replace.
Get an AC delco switch which should be available at a parts store. The store brand are all bad out of the box due to poor construction.
04chevyhoe
Thanks for all the information. This has been kicking my butt for a year, love to get it fixed.
---------- Post added at 09:11 PM ---------- Previous post was at 09:10 PM ----------
Is that the silver canister on the fire wall?
BRUTUS_T_HOG
Yes. The cycling switch screws into the side. There is a schrader valve so the switch can be replaced without discharging the system.
Goodinblack
I Like Tacos
Dirty South
Canister is the accumulator / receiver dryer.
Some cars /systems have a expansion valve in lieu of the cycling switch.
04chevyhoe
Thanks to everyone. I will replace the cycle switch and see of that is the fix.
Smityinms
