Please Help Guess the Part!!!
W
warriormagee
I'm not set up to pull the cover off. I would have to take it to a mechanic, dumping a couple hundred bucks in it at this time of year. Is there any way to determine if it is or isn't the u joint?
PG01
Up here to the right
Almost betting its the rearend but grab driveshaft by the rear and shake/twist it back and forth if you feel hear metal on metal... u joint... best bet would be mechanic tho, i think rear is gone. Hard to really tell you exactly over the internet but, thats my thoughts
W
warriormagee
It is the rear differential. There is fluid coating the underside of the vehicle. I thought/think it was fluid escaping from the vent hose being dropped below the differential.
W
warriormagee
I tried to shake the drive shaft, but it was solid/no sound from it or the u-joint.
Can someone recommend a replacement kit?
Can a couple of smart guys that can follow directions do this job in a weekend?
PG01
Personally, I would go to a junkyard and buy an entire rearend. Setting up gears in a rear is best left to people who know what they are doing. Prob be cheaper from a junkyard too than rebuilding it.... far be it from me to stop you though
W
warriormagee
I like your idea, and that was my first thought as well. I haven't seen any vehicles of my make and model at any of the places I've been. Are there any other direct fit vehicles I should be looking for?
PG01
Figure out what rear you have from tag in glove compartment and pretty much any 2000-2014 2wd tahoe suburban will work, you dont have to worry about matching gears in front because youre 2wd... depends on what gears you have or want...
W
warriormagee
This tag? Thank you so much. This opens up so many more options for me. This is just a family hauler, i don't do any mountain climbing or off-roading, so gear set up isn't a huge thing for me. Are there any hidden gems as far as gears go, that I should look for?
Krbobby
