YukonandtheHOE
- Joined
- Nov 11, 2016
- Posts
- 394
- Reaction score
- 181
I’ll throw my 2cents in. That is definitely an in-line filter, that hard line in the last pic is what that hoes connects to that goes under the engine compartment to keep the vents up high, over time the pressures created by heat in the diff propably siphoned the oil out of that hose because it’s so low or a leaky wheel seal. Generally speaking gears don’t make noise when coasting so you may have a bent rim or a tire issue causing the vibration.
