Plug with no home on the harness
rdezs
Sounds like you cooked a relay. The one that sends power to the ecm. Considering you shorted the battery cable to the starter, might want to get a handful of relays and replace them all. Don't be surprised if you killed the diodes in your alternator as well.....it's hard to say just how far the damage goes.
Very, very important to disconnect battery when working on stuff....
rdezs
Did you check your mega fuse right off the battery? You probably blew it.
D
dangerman4203
Mega fuse is fine. I’m showing po690 code. And the number 30 terminal for the starter relay is showing ground when it should be 12v constant
D
dangerman4203
And I haven’t noticed any drain on the battery. I’m guessing I have a damaged wire somewhere. Or the fuse box is damaged. Does anyone have a wiring diagram for the fuse block?
rdezs
Yeah something melted and arc welded itself to ground. Could be inside the fuse box or somewhere inside the harness itself. Potentially even inside the alternator. Could even be as simple as inside of a relay. I would start with the relays as mentioned earlier. Just replace them. With the extent of the electronics in today's vehicles, might chasing several components that are damaged..... And shortened the life of others. After addressing the weak links.... all relays and fuses..... I would backtrack from that starter cable that got shorted. Assuming you disconnected the cable to the starter and shortered it the block or to a ground, first stop is probably the alternator. From there the short could be fed into the harness.... And I'm not sure a schematic is going to be much help. Because you will need to unwrap the harness and inspect the actual wires along the path of the short. What you're hoping to find something that broke the connection to everything else upstream..... In effect, acting like a fuse.
You may want to get someone who's an automotive electrician by trade involved. This could get quite complicated. Don't forget, you not only grounded out the positive side of things, you sent current backwards up through the ground connections of various modules and components. Which I'm guessing may actually be where the problem is. Remember, there's no fuses on the ground side of things to protect the components.
D
dangerman4203
I dropped a wrench down the side of the engine and it hit the positive on the starter and grounded for a split second as it fell.
rdezs
I keep thinking about your mega fuse. You shorted the cable that goes directly to the battery. The mega fuse is there to protect everything upstream from that.... But the shirt would have to be over a hundred and some odd amps that the fuse is. Start simple. Replace the relays, double check all your fuses, take the alternator in to get it tested for free. I would almost bet money from past experience..... Lol, don't ask I was 19 years old..... But I would almost bet money the damage is in the alternator.
All the other electronic crap on today's vehicles is frightening. Stuff is sensitive.
I don't see one specifically for the fusebox but you can find electrical diagrams here (but back up to the GMC section for yours):
rdezs
I was pondering the idea that you might have a fusible link. I looked over my wife's 2014 Escalade which should have the same harness, there wasn't any obvious fusible links. Definitely need a schematic to find out if they stashed it in a section of the harness that's wrapped, if it even has one. I'm thinking that maybe the mega fuse replaced the use of fusible links? You might lift up your fuse box and take a peek underneath.
Stevemo70
