M Hankel
Sweet. Thanks, that helps alot. Those are almost identical to my 4th gen brackets.
The swaybar links are a bit different than I thought, but I might have a work around for those also.
Mike
NO!!! adjustable lower control arms do not do the same thing as relocation brackets tho. They are meant to be used to stiffen up control arms for better traction and less sway, increased stiffness in rear end. And if uppers are gotten as we'll, can both be adjusted out to recenter axle. But lower adjustable arms by themselves can only be used to stiffen up rear end, unless willing to adjust out for a positive or negative pinion angle.
Ive put over 50k miles on my 5" DJM springs and I did not use the hardware kit. I havent had any issues with them at all. Whether you have the hardware kit or not, the DJM 5" springs ride like crap.
Bro, I'm just saying they aren't the same as relocation brackets. Yes, they can do more then just strengthen up bars, that's why they are adjustable right? But by themselves, they aren't really meant to be adjusted, but hey, you know more then me. But to say they do the same thing as relocation brackets, is just plain wrong. But they are "meant" to stiffen up rear end, was the initial reason behind making square or round tube rear control arms. JUST SAYIN!
Sorry if I wrote something contradictory, just trying to help. haha, all good
All goods man, were all here to helpI'm just letting ya know, relocation brackets and adjustable rear lower control arms are two different things, for two different purposes. And while RLCA can move axle (when properly used with upper adjustable control arms) Relocation brackets can not move the axle, cause RUCA would still be in same position, so it would technically only change pinion angle if they actually moved RLCA backwards or forward. I have tried, and even when I removed or installed brackets, axle never moves. It's just not possible, since the brackets merely just reposition the RLCA lower, while keeping the same actual mounting distance in comparison to stock. If you were to look at the relocation brackets, the holes where the RLCA mount are just moved in correlation to axle mounts. I hope this all makes sense. The mounting position of arm is same distance whether installed directly to axle, or to bracket. So again, relocation brackets are just that, for relocating the RLCA to a better position/angle, and can't help lower, move or do anything else to suspension. Or they never did anything like that for my Tahoe.
I don't know everything, just learned while I did adjustments, and still learning. But I used to think the rear hardware kit did more in regards to suspension, and is deceiving how it's sold, IMO. But after using and trying different configurations, I know exactly what they can and can't do. And not saying people shouldn't buy or use them, but they just don't do as much as people think.
Just trying to help
