Popping from front end
Chubbs
The POP/THUNK noise that I was getting driving over bumps came from a faulty front shock absorber. I replaced them both and no more sounds. I dismissed the idea because they felt plenty strong when I swapped the torsion bar keys back in August or whatever. Just goes to show you...
BeenChevy
Minnesota
Had a clicking/ratcheting sound coming from the front drivers side during slow speed (less than 1 mile/hr) suspension travel - more noticeable when the wheels where turned to the right. This was resolved by only re-torquing my cross-member bolts. Will cost you next to nothing if this is the issue. There's a service bulletin about this and here's a related thread about it:
http://www.tahoeyukonforum.com/threads/crossmember-fix.19711/
CamReynolds
check the cv and even the spot where the uca meets the droop stop. if the uca is resting on the droop stop it will clunk when you hit a bump
ElMasBuscado23
