the only way you would be able to use the keyless entry if you unplug the aftermarket remote start is to use a factory remote, I hope i understood your question correctly, on my 06 silverado I am able to use the aftermarket remote(Viper Alarm) and oem remote. Lots of installers cut corners and just piggyback the aftermarket equipment to your oem wiring in other words the just crimp the wires and tap into the oem alarm(wiring) to avoid rewiring anything. So unplugging the afteramarket alarm will just disable that and not your oem k-less entry. Hope this helps.
Juan
Juan,
Thanks for the reply. I installed the remote starter myself and I believe that's the problem
. I didn't cut any wire. I found the the wires coming from the driver side door lock unlock button. There is connector just above the carpet, on the left wall. I connected my aftermarket keyless entry cables with two relays to these cables. I believe my only mistake was to connect + to the dome circuit. Last night I checked the right door motor and looks like it is not working right.. I took the entire right panel out and gave + - 12 volts to the motor directly. My left door began working after this but looks like right one is gone. After your reply I found my original fob which doesn't work well for the last 5 years. Looks like it locks and unlocks fine all the doors except the right door which is normal with that motor.
My problem is still the same. With the remote starter/after market keyless entry unhooked and all relay fuse removed ( I used 1 for lock 1 for unlock 1 for dome lights and 1 for rear hatch) when I press any unlock button in the car the driver door tries to unlock 2-3 times and when I press the dome supervision button (bottom left of the headlight switch) the doors keep unlocking (which was caused all the problems)..
I looked to the diagrams and there is a relay box under the center of the dash board (which I tested and works ok) .
The left door lock unlock goes to a relay box AND keyless entry module and the right door goes directly to the keyless entry module I have no idea about the rear doors. My guess is this 2-3 unlock pulse coming from the keyless entry module. I unplugged the relay box and connected +12 and ground directly to the door motor cables. I still could hear a relay pulled somewhere under the dashboard and I believe it is the keyless entry module and still the driver door unlocked multiple times. By any chance do you know where this module is?
Thanks again for the reply..
Regards
Kevin
