Smokymance
Boosted
Louis, where in Michigan are you located...
I am in the southeast area...
Have yet to visit a GM dealer yet...
My liftgate opens with the buttons, but won't open manually? Any ideas?
everything was working fine on mine this morning...went to the lake to drop off the jet ski, and the gate just unlocks and barely unlatches the gate...nothing happens just weird noises...open it manually, it wont even go down w the button...
Whats wrong with this thing????
Does it go down about a 1/3 of the way then open again?
Louis
GM Customer Service
Age 16 with a Tahoe LTZ, NICE! Life must be good for you.
Make sure you have the override button sitting in the override position, otherwise you will not be able to manually open the lift gate.
Straight out of the manual:
"Manual Operation of Power Liftgate
To change the liftgate to manual operation, toggle the switch on the overhead console to the “Disable” position indicated by a circle. With the power liftgate disabled and the door unlocked, the power liftgate can be manually opened and closed.
To open the liftgate, press the touchpad on the handle on the outside of the liftgate, and lift the gate open. To close the liftgate, use the pull cup or pull strap to lower the liftgate and close. The liftgate latch will power cinch to closed position. Always close the liftgate before driving.
If the RKE button or the power close button on the liftgate is pressed while power operation is disabled, the lights will flash three times, but the
liftgate will not move."
Hope this helps.
I am having the same issue, key fob opens hatch, overhead console button opens hatch but hatch button does not open hatch. Tried override switch, did not work either. 2007 Yukon DenaliIt is, lol. But I tried that and it still doesn't work?
Louis
GM Customer Service
