Power Steering Confusion?!
ecordell
CordellDesigns.com
Merica
you shouldn't be able to turn the key forward if it is locked.....usually you have to pull the wheel in the direction it was turning when it locked, then turn the key forward to unlock the steering, then you are on your own to strong arm it while the vehicle is off. If it is started then it should turn easily...
thehoe92
thehoe92
fo sho
The916
I see some of you are understanding it only like half way..
my car died while I was going 40mph
the steering wheel locked
even while rolling it was very difficult to pull it over into the side street
it only "unlocks" when the engine is running other than that it stays locked up
my question is why, if in my case your car dies and you NEED to steer it does it lock up?
I'll test it again tonight and see if maybe I do just have to pull harder but it didn't feel right
pittmanb8
If your car runs out of gas and dies, just leave the key in the ON position (not ACC) and the steering shouldn't lock. It will be hard to turn but shouldn't lock if you leave the key in the ON position. Try it in your driveway and see what happens- put the key in and turn it to ON without cranking. Wheel should turn and not lock.
thehoe92
thehoe92
fo sho
The916
okay I just went out and tried it and maybe I am just weak and its REALLY hard to turn 24's on a flat surface.
I feel like I'm going to turn the wheel to far and break something though
Ykn11Cg
