Power steering loss ?
garett
Can’t you just remove the pintle from inside the EVO/solenoid to “eliminate” the variable assist functionality completely?
J
jimpec
Brookfield Illinois
It sure is, long. I meant 180* degrees. Back to problem solution. Power steering now works right.
The O'Reily reman., 20 month old pump failed. The body is cracked internally and the inner plate was bowed out. So now i question if the EVO solenoid is good. Coil resistance is good. And that's as far as I went.
Blk00ss
Just curious, do '01's have hydroboost? I ask because our '05 suffered a loss of power brakes and power steering (at the same time) just for a bit about a year ago on a really cold day. After much searching and reading I learned about hydroboost and how the PS works in conjunction with the PB. And when something lets go, you typically lose PS and PB. I did a flush (ranger style) by removing fluid from the PS tank via a motocross fork oil level tool and added fresh fluid back. I've done this maybe 3 times in the past year and the fluid is much cleaner now, and the PS seems to be better and less noisy. The fluid that came out looked like Pepsi.
J
jimpec
Brookfield Illinois
Mine does not have HB. But some unit may. IDK.
Mine crashed at -8*F. The return line hose clamp was loose and I suspect now, that the air which infiltrated the pump may have frozen. This lead to the result of a cracked pump. Or O'reily reman. failed.
certa
