UpAndDown
Hi,
I have an 08 Tahoe LT. The passengers side rear power window switch recently quit. Window operation still works from the master switch on the drivers door. As far as switch replacement goes, does a brand new switch need to be programmed? If I get a used switch does it not need to, if a new one does? If buying used is an option to avoid that extra expense, does it need to be from an 08 or will any from our generation work and can it be from any window other than the drivers or does it specifically have to be from the passenger rear door of the donor vehicle? Thank you in advance for all replies.
