Powered Tail Gate failed
Thanks for sharing this.
Does you think if the struts are faliing it would impact the door motor activating?
I dunno, don't have it but thought the video was intriguing. If there is not enough support from the struts, maybe the motor senses too much resistance and doesn't work to preserve itself. I dunno, but changing out a strut is cheap and easy.
2007 Denali XL
NorCal
thanks, I am going to try that and will report back on the outcome.
2007 Denali XL
NorCal
Replace the other lift struts and see what happens.
Replaced both lift struts but has not fixed the issue. The symptoms remain the same, I am unsure if I should tackle the lift motor or the switch/lock on the tailgate.
The later seems to be working as I can operate it manually therefore I think something is up with the lift motor itself
Ok, and you do not have a Tech-2 or VXDIAG NANO? Either of those or a Snap-On bi-directional scan tool will identify the problem right quick. I've got a dumb tailgate, so no experience with them.
2007 Denali XL
NorCal
Here is a couple of vid showing the action from the tail lift motor when I press the button on the tail to close it.
BG1988
the motor is broken..
try applying 13.5Volts directly to the motor..(make sure the polarity is correct)
Garage2010
