PPV 1" taller
gat0r
DFW
i like it
& agree it needs a slightly wider tires
Super Sport
Normal, Il.
Would be cool if someone made a 20" steelie look alike wheel. Kinda like I've seen Chip Foose do with the '78 Trans Am wheels. That way you could have the bigger wheels and keep the stealth look... Lol
Bringing up an older post. Are you familiar with transport wheels? I have a 68 C10 and a lot of guys use them on older trucks. They are a 6 lug.
"Starting in 2012 GM introduced a “transit” wheel program for MY full-size SUVs and Crew Cab pickups to help increase *********** of 22” wheels and create a higher level of personalization. A transit wheel is simply a steel wheel, 22” tire, and TPM mounted to the vehicle during assembly which will be used to transport the vehicle from factory to dealer."
992dr
Eastern N.C.
Lookin good samuraj
Welcome aboard SS
Detroit Steel Wheels are another option from the transport wheels. They come in many sizes and widths.
The only difference is they are a solid wheel. If you know of any fab or machine shops, they can be easily made into large diameter PPV wheels. I had thought about doing that hahaha
S
Samuraj
Des plaines
They did rub...
Many small trimming need be done to rear well , and at the better weather I have to massage front wheels liner with a heat gun .
Tires are soft and pick in up road noise .
