It should settle a little. If you pull an air line and let all the pressure out then reconnect it and start the truck, how much does it raise it? If it’s more than 1/2” you can shorten the rods more and get it lower.Ok, I did what you said. it did drop a little. Thank you. I think it may be about 1 -1 1 1/2" inches lower than before. I can feel the difference when cornering. I'd like it to sit lower, but that's what I got for now. I'm at about 36 1/4" fender height in back and 35' in front. about a 1/4" lower on the passenger side. Once I wear out these tires, which will be awhile, I'm going to do a full drop and go to 22's. Perhaps it will settle a little over time?
Thank you sir.By the way, RocketMan, love your build, it's inspiring and I have learned a bit from it.
