Pressing the brake pedal, brake lights ?
"350Vortec"
*Tahoeless, For now*
On my buddys tahoe. If he presses the brake pedal down as hard as possible the brake lights come on, but if he uses them like usual they will never come on. Any ideas guys?
718frankb
LOCAL 282 TEAMSTERS
BROOKLYN,NY
bad or dirty switch or you can try to adjust it. the switch is not pressure sensitive it is travel sensitive
"350Vortec"
"350Vortec"
Thanks alot man, We figured it was that. Appreciate the help
TigerEyz3
Slow and Steady
TN
Tag...
I've got aftermarket LEDs and have noticed that the brake light doesn't work (light up fine for turn and when parking lights are on)...the factory 3rd brake light (also LED) works fine. Any thoughts on that other than something internal to the aftermarket LEDs?
718frankb
LOCAL 282 TEAMSTERS
BROOKLYN,NY
are they just bulbs or complete assemblys? if their only bulbs your going to need inline resistors on the brake lights.led's use much less power than a filament bulbs or you have them in wrong or wrong bulb
TigerEyz3
Slow and Steady
TN
They are the assemblies... were working fine then all of a sudden, no brake lights. Then as suddenly as they stopped working, they were back, and then gone again, but no return.
718frankb
LOCAL 282 TEAMSTERS
BROOKLYN,NY
your going to have to test the wires with the lights unplugged to isolate the problem
TigerEyz3
Slow and Steady
TN
Are you referring to the LED assembly side or the vehicle harness side?
718frankb
LOCAL 282 TEAMSTERS
BROOKLYN,NY
the truck side. if both dont work its probally the truck harness theres a plug behind the trailer hitch that gets messed up sometimes or if you have a trailer wire harness it could be that causing it too
Jeremytahoe
