Pretty sure my fuel pump is on its way out.
haks310
Got LEDs?
SoCal
Yeah, they're all ****** cell pics so I don't post them up. Thanks, Want to get it repainted white; grill and bumpers, hopefully by the end of next year.
Here is the link:
http://www.v-leds.com/Exterior-LED/...ED/V-LEDS-TYPE-2-DUAL-COLOR-p5851397-1-2.html
They are switchbacks. Check out the video at the bottom of the page.
It is true, you will get hyper flashing, where your blinkers flash super fast. You can easily buy an electronic flasher to replace the OE one...they're only like $15 dollars.
"350Vortec"
"350Vortec"
*Tahoeless, For now*
Here is the link:
So if i bought thesehttp://www.v-leds.com/Exterior-LED/Parking-Light-LED/White-LED/2-HID-WHITE-24-LED-PARKING-p4481028-1-2.html
It would work, but it would just flash really fast? Is this something that has too be changed because it will break something in the long run or can the upgraded flasher just be worked around?
haks310
Got LEDs?
SoCal
Yeah, they would just flash really fast. Not a bad thing, LEDs just require less juice to turn them on, you get the hyper flashing because the vehicle is designed to do this when a bulb is out. Since the LEDs dont require a lot of juice your truck thinks you have a bulb out.
Before you order them, order an electronic flasher from SuperBrightLEDs. You know where the flasher is located? By the parking brake, little square box. Should say "Turn/Hazard Flasher" on it.
I would get these though:
http://www.v-leds.com/Exterior-LED/Turn-Signal-LED/White-LED/2-WHITE-1157-V-LEDS-M-p6624816-1-2.html
They should be in-stock within a couple of weeks, they will be much brighter than the ones you posted.
"350Vortec"
"350Vortec"
Wow thanks alot Haks, Your always a big help to me man. One more question....Prob dumb and annoying...Which one of those flashers would i get?
haks310
Got LEDs?
SoCal
No problem.
Just take your flasher out and see what pin configuration it its. Should be the GM one.
I have a 95, they used two different flasher, one for the turn signal and one for the hazards, so I wouldn't be able to tell you on yours.I took a look at my brothers in his 99 once, but I don't recall what pin configuration it was.
ravingmadman
Chief Knuckle Buster
Greater Seattle
$300 is worth having the shop do it, if they weren't just quoting you the labor. If that's just the labor, you're better off doing it yourself, if you can find a heated place to work on your car...
JoseG
