Problems upgrading LED tail lights from VZMotors
Tahoewhat
Ballin' on a Budget
TX
I tried many ways. will try and post pics.
I looked again at mine and had to actually adjust the light downward so i could get the harness to plug in and just gently plugged in the rest. It was very tight, but worked.
Make sure the harness is not being held up by something. I.E. stuck on the body or something.
Y
Yngbld32
Hoover,AL.
So I decided to install them.
No problems on left side aftermarket
Right side factory.
Problem. Since the bulbs go in opposite locations and brake light is on top it was just about an inch short on right one. Was tight from factory terminal bus..
Modification...Extend wires
Finally....
Tahoewhat
Ballin' on a Budget
TX
Glad you got it figured out. Looks good.
Cscottsss
So those are the smoked lights correct? Have a link to where you purchased them?
BurbyRST
