I'm replacing my transmission, at the same time adding new 6an transmission cooler lines and a 40k aux cooler.
I was removing fittings from the rad (removed clip, pulled line no issue, but once I removed the fitting on the rad... coolant poured out... is this normal? Is there radiator fluid up to the seal typically?
If someone knows, please let me know.... (of course it is the fitting in the worst spot). TIA
