Question About Idler Arm
mattbta
Frisco, TX
I hope to not have to remove anything that doesn't need to be removed in order for me to accomplish the end goal. I plan on working smart and not excessively hard but sometimes that doesn't always work in my favor. In my research, the center link can stay put and the closest I will get to removing it will be changing out the bushing that mate it with the frame. But thank you for the knowledge.
Centerlink is attached to the tie rods at either end and then to the pitman and idler arms. Firestone took it completely off when replacing my pitman arm and tie rods and put it back on improperly. You’re right though, it can stay put.
Front sway bar is attached via bushings and brackets.
Good luck and let us know how it goes.
Rome58
