Question about ride height level sensors after lift
Kecker24
I put bilstein 5100s (small lift) with 2" lift blocks and my ride height level sensor seems very close to being maxed out wonder if there is a extension out there or something like that i haven't been able to find thank you for your help!
If I recall correctly, the end caps on the rod are threaded, so you can get threaded rod of the same diameter and thread specs and cut the threaded rod to a length that will place the sensor unit around the midpoint of its travel, when the truck is sitting parked.
olyelr
Elk Rapids, MI
Most spacer lifts come with extension brackets for the arms. You can also go the extended rod way to, but you will have to do all the homework to get the correct length to keep the electronics happy.
You have 2” spacers AND bilsteins set for added lift?
Jordan0277
