Questions about aftermarket headlights
l3aml3oo
Ok so I picked up some aftermarket headlights off of eBay. Have them installed with HIDs. Only problem is on of the lights is angled. If ur looking at the front of the truck the left side of the light is tilted up and the right side is tilted down. I know about the height adjustment and sweep adjustment but I don't hear anyone talking about a tilt problem. Any ideas?
L
l3aml3oo
Well its kinda to late for that and thanks for the useless tip
Andrew.
hes really not that far off. unless they are TYC or Depo's, you might be out of luck.
take them out and look at the mounting brackets themselves, see if you can tweak them or possibly drill some new mounting points for them so you can have them straight.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
It is not a useless tip. Did you have no return option? Can you not file a claim with paypal? You got a defective product, act on it. Get some better ones like tyc and avoid generic ones commonly found on eBay.
bowtiefreak
No Quarter
Near Philly
Yeah, Ebay lights are crap. TYC is the best option. As Andrew stated you could try mounting them into the factory mounts and see if that helps. Were the old lights this way also? Truck may have been crashed in the past and things are not lined up perfect.
FYI: We don't give many useless tips around here.
gitrduun
just rip your stock brackets off and use them ,i did that and they are fine
Abelton
