MassHoe04
What is the code tripping the check engine light?
I doubt overfilling the crank case with too much oil would have anything to do with tripping the ABS warning light as well...
I filled mine with too much oil after getting a false reading that indicated it was three quarts too low after I had the front end jacked up. I figured the time it took to get back on flat ground, that it would be OK the check the oil level. I guess I was wrong... It said I was 3 quarts low, so I added 2. That put the level way up over the fill indicator (into the dipstick part number)! See below.
I ran it almost three weeks with no ill affects. I did not cause any CEL or ABS lights to come on or trip any codes.
