Quick oil change shop screwed up
MassHoe04
Western MA
I am lucky to be able to slide underneath without having to jack the front or use ramps for oil/filter changes. Ten years ago, I was 45 lbs. heavier and could never fit. Now I can. Super-quick and easy job!
An employee of mine has an 05 Silverado. He told me without jacking the front end up, he has trouble getting the torque wrench on the oil pan drain plug... I said why are you making it more difficult than it needs to be?
He had a revelation when I suggested: "Just use a 3/8" ratchet and tighten by hand, making it just tight enough to keep oil in and call it a day..."
One 15mm socket, a 3/8 drive socket wrench and a strap wrench or band wrench for the filter is all that is needed for one of the easiest DIY jobs ever. Oil and filter change for less than $40! And, that is with 100% synthetic...
Juwan7233
