Quick question Brake fluid ??
HDRock1
Flint,Mi
These Hoes don't take Synthetic fluid do they, Just regular Dot 3 ??????????
taylorjm
Saginaw, MI
Doesn't the synthetic mix fine with dot 3 and 4 and provide higher boiling points, etc.
gitrduun
Taylor no, because dot 3 and 4 are glycol based, because the seals inside your pistons and master cyl are natural rubber, and any oil or oil based product will cause them to swell. You CAN mix 3 and 4 if you absolutely need to. But never either of them with dot 5
taylorjm
Saginaw, MI
gotta love products that use buzzwords like "synthetic"...makes you never even think that most things that are man made, are already synthetic! They got me on the brake fluid. I bought the "synthetic" dot 3 fluid when I flushed my brakes!
gpracer1
Phoenix
So is DOT 5.1
DOT 5 is silicone based and does not absorb water, the others are hydroscopic.
I always use dot 4.
Try this read.....
http://www.gomog.com/allmorgan/brakefluids.html
ousieks1
