Quite a few questions.
Mykal
WV
Vehicle: 2005 Yukon Denali XL With factory nav, rear entertainment and Bose system.
- Currently when playing a DVD I can either play the radio or play the DVD audio. Is it possible to play the radio/cd through the front speakers and the DVD audio through the rear?
- Can I do a VSS toggle to enable using the nav while moving?
- Where is the sub and amp located? What size is the sub and amp?
- Can I swap the sub out easily? The amp?
- Does the factory nav unit play DVD's?
- If I replace the factory nav will I lose the rear DVD player and screen?
- What's the best way to add iPod / IPhone integration to the stock system? Fm modulator? I'm not a fan of these though.
- Was a reverse cam ever oem equipment and did it use the nav screen?
Can I upgrade the factory nav system to a newer models nav system?
I've been reading the forums trying to find answers but I can't seem to find them.
Thanks for the patience.
TnTahoe
TN
If its the same my factory sub is located in the center console below the dash and the amp is located in the center console under the center compartment
OmarR
Indianapolis, IN
You can listen separately only thru the RSA.
Yes
Both are in the center console.
Sub - Considering the OEM enclosure, not really worth it. Amp - Yes, but you would have to also swap out the OEM receiver.
No
I *believe* yes.
You can buy adapters. PAC is one company that sells them.
No.
No.
M
Mykal
WV
Outstanding. Thanks for the answers. Much appreciated.
At least I can add an input to the mix.
llisumm
