Radiator for Tahoe with K5L
Flashpd
I have a 2013 Tahoe LTZ 4wd with the K5L Heavy duty cooling package. The radiator is leaking and I’m about to pull it and replace it but not sure if that K5L requires a specific radiator or if a standard with transmission and oil cooler connections will do?
St. Louis
I'm pretty sure the radiator is the same
Where is it leaking at? Sometimes the fittings on the side tanks going to the internal trans and oil coolers can loosen and cause leaks
F
Flashpd
Hard to tell but it appears to be the drivers side end of the radiator, but it doesn’t look like it is coming from a fitting.
F
Flashpd
Looking on Advance Auto the only radiator that mentions that it’s for the K5L is the AC Delco 21742, which is also the most expensive one at $614
gpracer1
Phoenix
They seem to like to crack on the driver side near the upper hose. Mine is K5L and after seeing the price I just went with all aluminum. So far works great in 115 degrees. Will be able to test in mountain driving Saturday, will check how it handles full throttle up the mountains to Prescott.
Foggy
KS
I'm confident that IF it has the trans cooler lines (they all do) AND the oil cooler then
they are all the same.. You should be able to find it for around $200+
Foggy
KS
GM GENUINE 21650 {Click Info Button for Alternate/OEM Part Numbers} Economy Info
FLEX Fuel; Exc. Enhanced Cooling Package (K5L); CORE SIZE 34 IN X 18-1/2IN X 1-1/16IN; w/ RPO Code APC,ASA,ATS,ADP,DEG,FAA,CAL,AJN,BBL,CCM,AAF4,0117; 6 Speed Automatic Trans.
$216.79
From the rockauto website
rhammond3
