Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
pwtr02ss
Tennessee
to change that i mostly just need to pull the pump right?
was prob just going to have them swap all the clutches also while its out and apart
Never been in an 80 but I'd imagine so. You can swap the frictions and steels out while you're in there. Just check tolerance and get it on the lower side and you'll be fine. You may have to buy a spring compressor to get some parts out. I'm really not sure
mikeyss
Longmont, Colorado.
I'm just lightening the mood here....
You HAD a 6L80
You swapped to a built 4L80 and broke it
Maybe it's time to try a 6L90 or an Allison, the old 8.1 had an Allison so maybe you could use one of those, lol
randeez
randeez
south florida
:upyours:
they use a different spline output so would need another transfer case. but no either way lol
was also a m300 billet input shaft, i beat on it for a while, whole buncha transbrake launches... i may have to start pulling timing on the shifts again if i want it to last for more than a year it looks like tho
pwtr02ss
Tennessee
Watched a quick tear down video. They took valve body and all that off, prior to pulling the pump. Once the pump is out, the input shaft comes out. Looked pretty straight forward and they used zero specialty tools during that particular tear down. Those are vastly different from a 60. Much heavier duty assemblies.
clublub69
