going back to stock, let me know if you want some parts
this has just about tested my patience and ambition.... i did go out to cars and coffee last sunday. after that trip it had some accessory squeeling. so i did the ol spray some lube on everything, power steering pump quieted down every time - great no problem. dealer wants $319 amazon $109...i really want this thing done but i guess i can wait till tuesday. tuesday comes shit doesnt get delivered till like 8 oclock at night. I got home a little early hoping it would be there and took off the old one, swapped turbo drain to ptfe, and (very important) got the transmission to shift into D3. before i could only get P-R-N-D- and no D3 cause of the lever on the shaft, the way this 4l80 (and every other one?) i guess when its in D3 it engages the clutches differently at launch. so i def need it to go there, and also my transbrake will only work in D3, D2, D1.
so PS pump/reservoir gets delivered finally swap it in right quick, fire it up and that wasnt even the goddamn noise. pulled all the idler pulleys, the tensioner is brand new, the alternator has about 1000 miles on it but 6 months old or so but it turned out to be the problem. so its like 8:30 i say **** it and run up to auto parts store and grab an alternator, swapped it and alls quiet.
been chasing my tail all week with tuning everything seems good at times then others it runs rough, so i start just at the basics. ignition coils, spark plugs, injectors. with hptuners you can turn on/off individual injectors but something wasnt working to try and identify any bad cylinders so i just pulled plug wires. cyl #3 pull the plug wire no change in idle. pull the plug it looks good, check the coil its sparking plenty, change the plug anyway, start it back up no difference pull plug and its bone dry. so injectors most likely gunked up. will be dropping them off tomorrow and hopefully they can get them done and i can pick them up at the end of the day. i re did a lot of the fuel system, flushed all the lines out but who knows, injectors could just not like sitting for a few months. hopefully they will clean up and get back to doing work. after i started messing with cyl 3 it wanted to run really rough and couldnt really get it running smooth enough to pull more plug wires but assumed all the injectors needed cleaned
Also have been baffled by some errant knock sensor readings at low rpm or even idle. it would idle along smooth for 5 minutes then knock sensor would pick up some noise and throw in like 8* retard. and you could audibly hear noise, but not like spark knocck and when you shut it off you would hear the same noise for a few minutes afterwards. couldve been lean cyl fire cause of injectors i dont know but that wouldnt explain it doing it after shutting it off. its a lot more noticeable on the passenger side but driverside valve cover is a lot easier to get off so i pulled it and it looks like rockers are hitting the baffles in the valve covers. so hopefully a new pair will get that straightened out
