Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
welllll screeching sound "may" have been self inflicted lol
so i got home - kid and i were at universal past couple days - decided to pull the turbo apart. got it down to the exhaust side (still in truck bolted to manifold). noticed one of the clamps was kinda bound up like it may not have been completely seated.
noticed there was some little scrape marks on the inside of the exhaust housing (white lines). sounded about a billion times worse that that looks but o well.
started truck up without the turbo guts, STILL shows fn knock . i just take a deep breath and put it all back together a little more carefully that last time aligning/seating the turbo center to the housings.
start it up, let it idle for a while, knock is a while lot less.
take it for another drive just in case and no more screeching sound and pulling time! drove it for about half hour, through some timing back in the low rpm, did some logging. everything seems to be ok
randeez
randeez
south florida
Seems be much better, drove around and heard it maybe like 1 time....I think the knock sensor may just be picking up some noise from fuggin 26X/26X duration cam, lift is in the .650 range iirc. May just have to adjust sensitivity of them.
Also I think I'm afraid to floor it lol. I'll do some logging and itll show tps at 100% for a second or two then just starts falling off.
Sam Harris
Texas
Nice!! Best case..!
Faulty TB or TAC?
randeez
randeez
south florida
makes a wee bit o noise in a moving gear, park/neutral alls good. acts like it has zero stall speed what so ever , kinda wants to stall the engine when put in gear, temp climbs uncontrollably even locked up and at idle, sounds needs to be up to hear kind of a grinding noise
literally in between /\ those vids it just works fine, noise gone.
fluid was trashed... i pulled the return hose let it pump itself out to make sure there was no restriction in the hoses or coolers - pumped about 10 qts into bucket in under a minute, i ran another 2 qts of clean fluid through it, drained pan, swapped filter. still junk i'll post some pics from my phone in a sec of fluid and pan
randeez
randeez
south florida
circle d specialties 258mm billet triple disc... was "spec'd" when i planned on just having a turbo 6.2 for a while.
not even locking it up under wide open throttle, but even some kinda mid throttle pulls are pretty violent in this thing and was prob locked up.
couple emails back and forth with them trying to figure out where to go with this... they make a 5x disc but wasnt really planning on locking up wot so wasnt going to bother with that. they do have a mechanical diode sprag option that is supposed to be stronger, or they may want to go back a little larger for some more girth.
either way need to get it and trans pulled back out, that amount of material i doubt could all come from the converter so going to have it cleaned and freshened back up while its down anyway.
ezmoney1981
