OK here goes...I have a 99OBS Yukon and at speed it has a random jerk every so often. Did a fuel pressure leak down test (Good), new trans (so not that either), all new distributor, wires, spark plugs, ignition coil, cap, rotor. Maf cleaned, no vacuum or intake leaks, no engine lights or codes. Ran a very expensive Mac tools diagnostic scan tool live while driving with no misfires or drop in rpm (which is almost impossible). The truck literally jerks so hard you can hear it in the driveline and it sounds like the whole engine shuts off and starts back up in a split second. I can almost perfectly replicate the jerk if I speed up and slowly back off the throttle. Just not as noticeable of a jerk then. I have researched this until I'm ready to sell the truck... The only thing that came close was a guy on another forum said he had the same issue and after pulling the intake they found two of the spider injection lines backwards. Would the truck even drive if this was correct? I have ran bottle after bottle of fuel injection cleaner to no avail also in case I have the clogged poppet issue that GM did a recall on. And yes the motor has been replaced but no way to tell if it was just a short block swap or long block swap. No way to know if they had to change the intake to screw with the injectors. PLEASE HELP!
