Random traction control light when turning
I would connect the tech2 and watch the abs sensor live data while driving, even though the hubs are new. If all 4 feeds are moving smooth then proceed to checking the steering position sensor. The problem with this type of issue is there will not be a code stored until whatever it is completely fails and the service light comes on in the dic then there will be a bcm code stored.
you could try doing a full module scan anyway and see if maybe it saved a history code but unlikely.
I had that experience for a month or so last year, turning into my street at speed (left turn, and then immediately up a hill). It did not generate a code, and then it stopped, and has not recurred since.
91RS
GA
It’s because you’re lowered. Both of mine do it ever since I did the 2/3 drops.
kbuskill
kbuskill
NE. FL.
Mine was 4/6 dropped for 2 1/2 years and I never had this happen. Now it is only 2/4 dropped and just recently started happening intermittently.
Just seems weird.
4plemons
