Range of cost for rear main seal job at a shop?
Scott in AZ
Arizona
I don’t really know what a torque converter is except I gather it’s the twisting energy transfer between the engine and the transmission. And the main seal must be the seal between the Engine and the torque converter? Or is the torque converter a sub-assembly inside the transmission and the main seal is the seal between the engine and transmission?
I’ve heard different recommendations on the torque converter. If my transmission is running fine at 171K miles, with no leaking, should I proactively replace the Torque Converter and main seal? Or at this point should I just wait for the tranny to have problems before opening it up? What do you guys think?
Geotrash
Dave
Richmond, VA
This particular conversation about replacing the torque converter only applies to the GMT900 and the 6L80 transmission. Your 2001 with the 4L60 doesn't have the same problem.
To clarify though, the rear main seal is the oil seal around the crankshaft between the crankcase and the flywheel. The torque converter bolts to the flywheel and transfers power via fluid between the engine and transmission. It primarily is needed to allow the engine to idle while the vehicle is stationary but as engine RPM increases it transfers increasingly more of the engine's rotation into rotation of the rest of the transmission and drivetrain. It is technically part of the transmission assembly and is essentially a turbine disk and stator.
Charlie207
Charlie207
LFOD, New Hampshire
The VLOM itself and the oil pressure sensor if that hasn't been done recently. Might as well do the valve cover gaskets, too. Might be a good time to replace the evap. solenoid while you have the fuel rail apart. And of course new intake manifold gaskets.
Valve cover gaskets and oil pressure sensor are recently done. (oil pressure sensor is the leak, i think)
Does the VLOM need to be changed if it's not leaking? (or, also if it's been deactivated from BB tune?).
wjburken
Eastern Iowa
The VLOM doesn’t need to be changed. The reason it was mentioned is there have been a number of cases where the bolts holding the VLOM down have loosed up overtime, letting oil leak out. If you have the intake off already to check the torque on the VLOM bolts, might not be a bad idea to take the VLOM off and replace the o-rings under there.
Charlie207
Charlie207
LFOD, New Hampshire
That’s why you put a sheet of 1/2” sheet of plywood on the ground first.
How much does a 6L80 w/2-speed transfer case weigh? (for science)
Probably a lot more than the last time I removed/refitted a gearbox... the Saab 9000 5-speed was probably 125lbs, and three of us just lifted it up over our heads and slammed it home. Then I looked over and saw the new slave cylinder sitting on the cart, so we got to do that twice.
Fless
Super Moderator
Elev 5,280
I'm not familiar with the transfer cases in the later gens but the earlier NP246 two-speed TCs run around 80 lbs. Just the transfer case.
Geotrash
Dave
Richmond, VA
Agreed. But the reason I mentioned changing the VLOM was twofold: 1/ As you note it's the source of leaks, and it has an integrated gasket so it's easiest to replace the whole thing if the intake is off. 2/ There is an updated design that solves some of the root causes of AFM failure so in case his was still active, the new design with brand new components would add reliability.
SPIS
