rattling noise 07 tahoe
Ben
PCB, FL
I had this issue for awhile come to find out the D pillar on the right side had one of the clips break off and was rattling against the back glass. Fixed it with some 3m double sided tape real fast. Easy simple fix. Easy to check too, remove the tail light then remove the D pillar, just pull it comes straight out.
KMeloney
Mine sound is coming from under the truck/the engine bay. It's not an interior sound.
04ctd
Charleston SC
FWIW, you can jack up the rear of the tranny yourself, just a bit, and see if the tranny mount is separated
obviously, don't jack up the center of the pan, or you will crush the pan, and dont' jack it TOO MUCH, or you can rip it. just a bit of upward tension in a solid area of the tranny.
it's an upper and lower shell, with a hunk of rubber in the middle, and they usually come apart in trucks over time (i guess from working?)
not sure if these SUV's work enough to hurt them?
i do NOT think this would be metallic, like a heat shield...this would be thuddy & heavy.
FWIW part 2: pull the jack cover out, and look in there. my SUV was used, and had two tire chocks in there, and there were rattling ALL OVER back there.
they are light & "rattly"
they are on either side of the jack in this pic:
http://cgi.ebay.com/ebaymotors/SUBURBAN-SIERRA-SILVERADO-YUKON-TAHOE-Z71-4X4-4X2-JACK-_W0QQcmdZViewItemQQhashZitem35b32ee807QQitemZ230639462407QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
SBCT
I had the EXACT same problem so maybe I have a solution for you. Metal rattle sound? Mine sounded like it was coming from the passengers side of the engine bay. Happend every time I accelerated decently hard or anytime there was a load on the engine such as going up a hill/grade. Problem was very difficult to diagnose because it only did it under these conditions so obviously I cant open the hood and listen for where its coming from since it only did it while I was accelerating. Went through the usuals, exhaust manifold heat shields, etc... nothing fixed it.
So... turned out to be the A/C lines that run along the passenger side of the engine and then downwards between the back of the engine and the firewall. The lines were rattling against each other then the engine would torque up apply pressure on the A/C lines. You can either manually try and separate the lines a little father apart from one another by sticking something in between them such as a thick piece of foam or something similar. Worked for me and now I can beat on the truck giving it full throttle and no noise! (Still get all the inside rattles, just no strange rattles coming from under the hood)
KMeloney
Now THAT sounds like it could be it! Thank you. I'm going to check it out.
Can you tell me where they were most likely rattling? Could it be a number of places along the length of the lines, or is there a most-common place where they likely rattle?
I'm really hoping this is it. Thanks a lot for the input.
KMeloney
I think the ac lines are going to be the culprit. I looked at them at lunch, and they're are definitely touching at at least one place high up near the fire wall. So, I wedged something between them temporarily there. But it looks like they turn to the left at the bottom of their downward run, and there's a small heat shield there. So, the lines could be rattling against each other AND against the heat shield, too.
I really think this is going to be the source of the noise. I'll report back.
L
leileisdad
Denver, CO
so today i took it to another local shop, I happen to know the owner from High School, so he looked at it for free...
so he could not duplicate the noise, so when I went to pick it up, we took a ride around the block, we went back to the shop and popped the hood, he determined that it is a knocking noise from the engine.... he said its almost "normal" with wear and tear. Its not really loud, its happens when I accelerate... anybody familier with this?
Thanks!
SBCT
All I did was separated them a little further by hand just by spreading the lines farther apart with slight pressure. I was doing this right in the back of the engine where the lines are on top of the engine and then make the downward turn between the back of the engine and firewall. This worked as a temporary solution and the noise would slowly come back so I put a thick piece of foam that i cut to size in between the lines at this same spot and it has so far worked for me....
KMeloney
Putting some rubber between the upper portion of these lines hasn't cured me of the noise. Didnt get any isolators down lower on the lines yet, but I'm beginning to think that these aren't causing the noise. I think it could be contact between two heat shields low on the engine block, maybe (you can see them through the front left wheel well). Still need to do more investigating...
SmoothADetailing
