Rear Anti-Sway Bar for 1999 Tahoe
rbirkey
Hi, I am the relatively new owner of a 1999 Chevy Tahoe LS, 4DR, RWD, 5.7L Vortec with no rear anti-sway bar. I have upgraded the front anti-sway bar with a Belltech. I wanted to do the same in the rear (Belltech 5512), but they do not make one for a Tahoe with no factory anti-sway bar. I am looking for an option to add a rear bar and the choices seem to be extremely limited. In fact, I've only found one so far... the Roadmaster Item # RM-1109-144. See https://www.etrailer.com/p-RM-1109-144.html?VehicleID=19991023834
Does anyone have any experience with this product and option, or have found a better option?
rbirkey
rbirkey
Has anyone installed the Nolathane Z5690 sway bar on the rear of a 99 Tahoe?
Contact Hellwig and see if they make a rear sway bar to fit your truck, as it looks like they do.
REAR SWAY BAR GM 92-00 SUBURBAN, TAHOE, YUKON, DELANI 2WD, SUBURBAN, TAHOE, YUKON 4WD
Part Number: 7608
Rear Sway Bar Kit
For your money, the best aftermarket investment you can make! Hellwig Sway Bars are an extremely effective handling upgrade you can make to your vehicle. Hellwig sway bars offer quick bolt on installation that are engineered to perform. An immediate improvement will be felt when you drive through the first corner with a Hellwig sway bar installed. Though most vehicles come equipped with factory installed sway bars, they are often insufficient for today?s load and tow demands. Hellwig sway bars feature larger than stock diameters and precision engineered components to optimize handling and reduce body roll.
Hellwig sway bars are quite pricey, but they virtually eliminate all body roll. I'm sure that you would be quite pleased with this brand and its performance, so much so, that you might consider getting a Hellwig front sway bar in the not too distant future.
rbirkey
rbirkey
Part Number: 7608
Rear Sway Bar Kit
I have contacted them but they have not responded. My Tahoe is RWD, not 4WD. Thanks.
rbirkey
rbirkey
Joseph,
I have contacted Hellwig but they have not responded. My Tahoe is RWD, not 4WD. So I asked them if they have a product for my Tahoe. No response yet.
Thanks.
rbirkey
rbirkey
Hellwig got back to me and their kit 7608 does include everything I need for a 99 Tahoe RWD without a factory sway bar. So, I will report back on how it goes! Thanks.
Malachismith
