Tbruz
Just found out both rear axle seals are leaking.
1997 Tahoe 2 door with 105K miles.
Since the temp is around 18 degrees here in NH, my local mechanic will do the work.
two questions;
While he's in there is there anything else I should replace like axle bearings?
How much time($$) should I expect to be hit with?
I had planned on changing the diff fluid in the spring so I already have Amsoil and a new gasket sitting in my garage.
Thanks,
Tbruz
two questions;
Thanks,
Tbruz
