Rear bumper lower trim piece?
18tahoelt
Thanks to the member who posted the original instructions! My install went well and completed in about 1/2 a day in the driveway. I went with all factory parts (list below) and painted the tips black with some high temp paint!
Want this on my 21 AT4 i just got..looks so much better with Dual!!
18tahoelt
Anyone in the Chat know if the Stock Dual exhaust from a Yukon with 6.2l will fit on a Yukon 5.3l. Getting mixed messages. Worst case could be modified to fix by a exhaust shop..Any help would be greatly appreciated
K5-Z71
TX
No, it will not work. The pipe diameter on the 6.2 is larger, studs on the mounting flange are spaced further apart as well.
A good exhaust shop can chop and weld anything you ask for!
18tahoelt
Thank K5-Z71.. had a feeling that was the case. Appreciate the info..looks like I am cutting and welding!
Acroston18
I plan on doing the same thing. There is no modification that needs to be done, correct? The dual exhaust hooks up pretty easily? Do you have pictures of the underside where it hooks up behind the spare tire?
Acroston18
Hi all, I have a 2023 5.3L Tahoe LT. Does anyone know if the 84964238 dual exhaust will hook up with no problems or will I need to make some modifications?
Chase_S
I’m new to this forum and I would like to do the same. I recently bought a 22’ Tahoe RST. I’ve searched the part number provided in this thread and when I enter my vehicle info an asterisk comes up and it says does not fit your vehicle. Has anyone else seen this?
RobMuff
