Rear diff swap compatibility
GMC Yukon
Well did it work? Iam looking to up garde to a rear end with rotors.... Smae thing came from a 4 door and I have a 2 door ..... Same size gears... GU6 3.42
retorq
Kingman AZ
Are you in the right area?? What year are we talking here?? I didn't think any of the OBS had rear discs from the factory ...
T-Bagg
The Esca-Hoe driver.
Doesn't Matter
The internals from a four door 10 bolt will swap with the internals from a two door 10 bolt. You don't have to upgrade to the 14 bolt rear end if you're not really going to abuse it, i.e. Sudden throttle inputs, off-roading/shock loading.
If you found an axle that already has rotors in the rear I don't think that will affect the internals. You may have just gotten lucky. But if both your truck and the donor truck are GMT 400's I'd bet a dollar you're good.
Dremar79
