Rear differential replacement help
Erickk120
Actually try contacting a drive line shop, they can probably do it the cheapest, and have the knowledge required to put it back together the same day.
02ncHoe
02ncHoe
Thanks! Will
Definitely look into that
Chris2144
Usually the local junk yard has a bunch of them tell them you want to pull covers off and check them I have found newly rebuilt ones this way. Fyi it's not hard to rebuild it I've done one in the driveway before cause I didn't have a garage. You need a dial indicator with magnetic base and a torque wrench plus other basic tools. Also a slide hammer works well for getting the axle bearings out
Chris2144
As a side note I'd you rebuild it go with a true trac big improvement over the gov bomb
sdhouseofwax13
