Rear drop shackle help
blue99tahoe24
blue99tahoe24
bout that tahoe life
joliet il
Not sure of height since I haven't measured it with the factory's. Being a 2wd and is lowered 2in's from the factory also. You may have to come down another 2/3 drop from how your sits now.
Sent from a Phone Booth using Tapatalk
Ok coo because it sits level now 34 1/2 with the 24'on
Sent from my PantechP9060 using Tapatalk 2
OkcLarryD
Okc, OK
i've got a '97 2 door, 2 wd and I'm having trouble with the shackle rubbing on the fuel filler neck, the rubber part.
How have you guys gotten around that?
thanx
Tricky
Illinois
thanx
Did you get it worked out? Plan to do mine next week when I get some time off.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
thanx
In rear you have to unscrew the factory bolt that holds the cargo hook and get a M10 65 mm x 1.5 pitch bolt. then get one of these clamps and tigten it up and will clear the shakle. anything else just hit me back
Tricky
Illinois
So his being a 2dr is different than the 4dr and needing that clamp.
Tricky
Illinois
Just finished mine, took 1 1/2 hours.
Tricky
Illinois
Thanks, funny driving to bone yard now and looking out side mirror and see the rear end lower.
slipping
Rosamond, CA
haha, yeah thats cool. i need to get some lift shackles to bring it up even instead of the cali lean. probably hit tony up next week about it. yours really looks good though. my boy just asked if it was darth vaders truck and if there are any storm troopers inside.
Tricky
Illinois
Thanks, and it's just a ex- Military, current Postal worker and his lil friends, .
Legends61
