Rear Heating Solutions
noJeepshere
Bountyfull, Utahrd
Rear Heating Solutions HVAC guys weigh in
So, living up here in the great white north means cold for much of the year, with a few months of warm weather tossed in for good measure. So I'm looking into installing a rear heater in my 99 Yukon. Thing is, those ceramic heaters (or anything electric, heat wise) have a tendency to catch fire and burn cars to the ground. Two have been crisp-ified this winter here. So I'm looking into adding onto or modifying the factory rear-ac system to blow hot air in the winter. There are some outfitters up here that will plumb in a rear heat system, for a price (read: mega $$ for a poor guy) and since GM felt Tahoes/Yukons didn't need rear heat until the body style change, I can't just order up the parts and do the work.
But that got me thinking, what if I stole parts from an obs Suburban? It may not necessarily mean heat on the feet, but it's better than nothing. So today I stopped by the Stealership to do some research, comparing the two systems (Tahoe rear-ac and Suburban rear heat/ac) and spoke to a tech, and it seems not only feasible, but relatively easy! I can even have floor heat in the rear with this possibly, I'd have to search a little more on that. And I can even have heat (and a/c) in the cargo area, which has its obvious benefits.
I have a project for the summer :D
SunlitComet
OBS Jedi-Do Good
unknown at this time.
use gmpartsgiant to look up the various configurations to see what can be mounted up. Are you by any chance looking for faster coolant warm up too?
noJeepshere
noJeepshere
Bountyfull, Utahrd
I will keep that website in mind when I get more serious about doing this next summer, thanks.
As for warm up, I could install a webasto or pro-heat module for a reasonable price, but it actually warms up pretty fast after being plugged in and idling for about 15 minutes, even at -40. My real concern is that the rear does not warm up, ever, there will be snow in the back after a long trip, even in milder weather.
Okcderek
I am completely interested in this. I would love my rear ac to be heat and ac as well.
noJeepshere
noJeepshere
Bountyfull, Utahrd
you can tinker with the idea of turning it into a heat pump system.
Elaborate please? I know the theory and principle of the operation of heat pumps, but how would I make that work in my Yukon?
---------- Post added at 03:13 AM ---------- Previous post was at 02:52 AM ----------
I did a bit of research and found that heat pumps have their limitations, ie. the coldest most operate are called "cold climate" pumps and run down to -30f, which is still short of the temps I see up here. That and ice buildup on the outside coils would render them useless after a while, prolly a hour or so, without some way of heating up said coils to defrost them.
Good idea Jonathon, but not practical in this situation.
noJeepshere
noJeepshere
Bountyfull, Utahrd
So, I there is a hitch in the idea, the Suburban's rear heat-a/c setup is ginormous, easily twice the size of the Yukons... I need another idea...
On a side note, it's super easy to put vents over the cargo area:hands:
I'll post pics tomorrow of what I've found.
noJeepshere
noJeepshere
Bountyfull, Utahrd
Here is a pic of what I've found:
The heater core from the Suburban is a little big:
Something smaller sized could work. My idea right now is to put a heater core there, plumb it in, but put a cut-off valve under the hood for the rear heat. I figure since the rear a/c is on or off, the rear heat can be on or off, and just control the amount of heat with the fan. I would get one that has the hose couplings on the side to make drilling easier for the hoses though the body.
FPinzon
