lspann3525
- Joined
- Feb 22, 2023
- Posts
- 112
- Reaction score
- 145
I have a 2008 Tahoe Z71 4WD that has a oil leaking coming from between the engine/transmission. Over the years I have changed the oil pan gasket several times thinking that was the problem but it seem to be the rear main seal. The valve cover gaskets have been changed recently and while doing them I tried checking the valley cover pan but didn't see anything.
So that only leaves me to believe the rear seal is the problem. Ive watched several videos on moving the transmission back to get access. But im kinda discouraged because this is a 4x4 and the transfer case and transmission look huge together. I have a transmission jack that I will be using and maybe a floor jack for the transfer case.
My question is can the transfer case be removed to make it easier for me?? Are there any kind of special seals between the transfer case and transmission that could be damaged during removal.
And also anyone have an easy way of doing this?? I know the exhaust is going to give me hell
